zetor tractor won't move forward or back gear grinds
sumaljagdeep
zetor4340
got a zetor 4340 that will not move forward or reverse, when you put forward and reverse leaver in forward won't move you can hear gears grinding like they are worn or a bearing is gone and sat has dropped? not sure whats wrong and if its an easy or hard fix? can it be looked at some how?
Can you put it in gear with the engine off ? It might be a bad clutch cylinder.
