Hi Folks,
I need an automatic reciprocating hydraulic circuit to operate off my Zetor Crystal's hydraulics. The desired function is to automate the function you would get with a two way spool valve that causes a cylinder to extend and retract. Normally this is done by manually moving the spool valve control lever. I would also like the cycle time and the dwell time i.e. the amount of time the cylinder spends fully extended to be programmable and to have a fast return function.
I will send a six pack of Guinesss to the first person to post an implementable hydraulic circuit diagram to achieve this. Get thinking folks...
Could a newer tractor (Zetor or other) with programmable electro-hydraulics be setup to perform this function?
TomZ
[glow=green,3]Tom in Ireland[/]
TomZ
