clamp for holding pto clutch, preesure plate
thomas
thomas
is there a tool, special clamp for holding the pressure plates togetheir when i change the pto clutch,
tried doing it with g clamps , but finding it hard to keep clutch centered, it,s about 2mm of center:mad:
I never had any problem aligning them. Sometimes just put a long bolt in, then push the clutch pedal to release the spring pressure, then put a pipe wrench on the PTO to turn the input shaft splines in line. just some wiggling.
