- Joined
- Jul 5, 2003
- Messages
- 3,968
- Location
- Laag Zuthem
- First name
- Renze
1967 3011
You have to get used to it, but the red wheels give it class.. I still think it looks gorgeous... Best Zetor design ever. Screw Pininfarina.
Review from a contractor around my work area: You can feel it has a long wheelbase. It pulls and rides like a freight train !! (They compare it to a JD 7810 which in fact has allmost the same wheelbase. Perhaps the tires are less jumpy, or the Carraro axle trumps Deeres TLS ?? (I know TLS with its short tracking rod, reacts funny when a heavy tandem trailer is pushing the drawbar aside when driving curves... the independent Carraro doesnt have that shit)
Their main complaint was that because of the low placed cab at the back of the tractor (where it has been on short 4 cylinder Forterras since 1991) makes it very hard to look inside the silage trailer, and also hard to look over the hood... Well that was what people were saying from the start..
Another complaint was that it still had the armwrestler style external hydraulic levers... Yup people also said that for a decace..
Short said, when Zetor brings out the Crystal CL (version two) it should have the cab moved up an inch or three, and two inches forward. It would solve all visibility problems. Next to that, it makes room to use the Proxima cab with the arches above the wheels, and mold a good mudguard inbetween this curve and the Crystal 650/65R38 wheel. Yes, and i mean Proxima cab including the external hydraulic spools: When the cab is placed higher, the lever mechanism should have enough room above the wheel in the Crystal as well...
And then it needs an 8 ton rear axle. Deere is offering 8.5 in the M series, 10 ton in the R series. Fendt is offering 8 ton and 335x10 lug pattern even in the lightest 700's. For interchangeability with the Forterra which also uses 38" rims, (and later use 10x335mm only with 42" rims on the 200hp tractor) i would opt for an 8x275mm lug pattern and 15mm rear rims for the Crystal, Valtra and ZF prove its possible, with the proper flange transitions.
Really, the Crystal has everything you need on a basic tractor: Automatic powershift and hitch tronic are provisions that make it stand out from a used Deere or New holland (with which it will compete even more than with a new Deere or NH), the looks are great, the ride is great, and the transmission is perfect for a basic tractor. It just needs a better positioned cab for a better overview, better hydraulic levers, and better positioned gas struts so you dont have to get out of your seat to pull the door closed, and then yank it again against the force of the gas strut to get it to catch the lock...
They are so close, yet far away.. Its the 80/20 rule: with the first 80% of provisions you get only 20% customer statisfaction... With the last 20% of provisions, which make a basic tractor work really well, gets you the other 80% of customer statisfaction...
The Mercedes slogan applies even to a very basic tractor: The best or nothing. The things you put on, should be executed to perfection. If you cant, within its price bracket, then dont put it on it at all... Fendts 300 series was very basic, but what they put on it, they did right... (even though they dont last when putting out more than 90hp) and it was Germanies most popular tractor for two decades.
When looking at the annual reports, they describe new developments even more vague: Something about user improvements. I guess (and hope) that means a redesign of the cab...
Furthermore the Zetor Minor 50 is proposed for 2017.. American dealers will be delighted
Here, i was bored today (waiting for the heater repairman) so i tinkered with the cab position a bit:
It will solve all visibility issues, both over the hood, and into the silage trailer (or to the harvester pipe)
Furthermore it creates room between the cab interior panel and the wheel, so the four hydraulic remotes of the Proxima can be fitted on the Crystal.
Those two modifications alone, along with the door strut modification, would double the marketability of the Crystal because of first impressions.. then later an 8 ton rear axle for longevity in contracting use, and thats your Crystal Then later, along this Crystal CL, add a DSG gearbox as Crystal DS, (with load-sensing pump, mechanically controlled) and then a version with DSG gearbox, LS pump and the electrohydraulics of the Forterra HD.
