Hello.
left brake will not release on rear of tractor doesn't seem to be corrodied on activator rod. Haven' t tried to bleed off system really don't know much about the zetor tractor. Any suggestions greatly appreciated
It could be the slave cylinder rusty or the linkage pins siezed. Check the handbrake cable. If all is free try loosening the bleed screw. If this cures it then it could be the master cylinder.
