Hello.
Is there enough oil on the power steering?
Is the correct oil on the power steering? (HLP 46 or in northern states better HLP 32?
Is there play in the ball joint heads?
Is there play in the rear mount of the power steering cylinder (fork)?
When was the cylinder last lubricated and with what and how much?
If necessary, check the clutch of the steering hydraulic pump (remove and check the tooth profile).
Hello folks I haven’t looked into any issues yet.
First concern ie rear arms won’t raise more than a foot, oil is full, front loader works fine & pto spins fine. Any suggestions would be be great.
To all:
Thank you for the help , I figured it out. I removed the right fender used WD40 on the lever hinge points and it now goes up and down. Does anyone have the max height of lift from the ground up to center of the lift arm holes?
The max height can be varius. Big tyres gives a higher height and smaller tyres a lower one. So its the best to messure it on your tractor for a exact result I think.
