Markku,
Yes i also took lots of pictures of the scenery, with parts of Leena's Merci on the edges..
Gerlant likes your taste of cars
Yes i was so impressed by the blondes that i didn't dare to take a picture of them, only the tractor they drove...
now nobody will believe us..
Anyways, i have cleaned the heads with sandpaper and they dont look to bad. One valve has a star like figure in it, it will be o.k. but i will change all the valves just to make sure... they are less than 15 euro a piece so i'm not going to worry about polishing used valves at all...
Last saturday, Gerlant and i picked up a front loader bucket from the northern province of Friesland, via an advertisement website called marktplaats.nl
Now i got a nice 500 liter, 2 meter wide bucket, that will be exactly suited to the capacity of the loader..
Tomorrow i am going to ask at my friend's work, for the price of a 4 section double acting valve block with Bowden cable control.
Then i will need only a feed and return hose, and then attach the hoses from the loader directly into the valve block. Otherwise i had to use 10x 2 meters is 20 meters of hydraulic hose extra, to put the oil lines via the cab, leaving no room in there at all...
This will be cheaper and better...
Pushing trees, scrubs and brushes into the bush, is a world of difference... at our branches dump place, the
Zetor pushed 3 trailers of branches further than the Deutz pushed only 1 trailer load of brushes..
You get used to luxury pretty easily
