question leaky crank seals what oil to use?
zetor3545
matthew morgan
Hi people.
I have a tractor at home which has leaky crank seals. i dont reall y want to go about changing them as it is a big job!
to try and stop her from leaking so bad im using hd30 oil. which is better but once used a bit starts leaking again. i was wondering which oil should i use to save her from leaking. i could use hd40 but when cold it would pull hard on the battery.
Would fully synthetic 15w40 be better as synthetic is known for (clinging on).
any help would be apriciated.
You will have to change your name plate now to the 34year old tractor man.
