- Joined
- Jul 5, 2003
- Messages
- 3,968
- Location
- Laag Zuthem
- First name
- Renze
1967 3011
If you look at the trailer in the last video, thats about the size (20 m3 or 15 ton) they hang behind a 164hp tractor in the UK, but not quite the drawbar load we are used to, on this side of Europe. Drawbar loads of 4 ton are not uncommon and a newly introduced tractor should meet this unwritten market demand... (i tell you this axle isnt going to last when its carrying that 5 furrow Kverneland plough with packomat for a couple of years... Here, an old Ford 8630 was pulled back from semi-retirement to do that job, it didnt need the power to pull, but it needed the axle to carry it, which a Fendt 514 didnt have...)
It seems only a few are out there yet, running field trials and demos in Poland, Czechia and Hungary.
Zetor UK rumors that the version 2 is underway, so most likely they are gathering customer feedback from selected customers, which is good as long as they dont focus on the criticism of people that compare apples to oranges: The Crystal is a straightforward drafthorse, with enough features to make a long hard day of work a little easier, but no bells and whistles, and gets both its fuel efficiency and reliability from a low friction, straightforward gearbox. Comments from customers that arent interested in such concept, should not weigh in on the scale of deliberation because they wont buy a Crystal class of tractor (JD M series class ) anyways, but are looking for a higher end tractor (JD R series), which Zetor cannot offer yet... Stuffing a JD M series class of tractor with R series features (like the Forterra HD) isnt a bright idea because it marginalises its market potential for being either too expensive for the M series buyer, or under-equipped for the R series buyer...
Anyways, a big lump of rear axle, and an updated cab interior with all functions integrated in the rear side console (hand throttle, EHR, external remotes) in an ergonomic fashion, and putting the cab slightly higher above the hood, will be the finishing touch for this bold looking tractor, in a market segment in which the Zetor brand has the most potential
