Hi guys.
I'm really at a loss here. My 9540 overheated the hydraulics last year and burned out the sealings in the main hydraulic lift cylinder.
1 month ago I changed the main hydraulic distributor along with the safety valve, I replaced the hydraulic pump for the gear shift and the the pump for the main hydraulics( with a 60 liter pump) along with its safety valve . All filters and of course the oil.
What was wrong in the beginning was that the shaft controlling the original main two hydraulic outlets got loos from the distributor leaving it half in open for one of the external outlets.
When the tractor runs now you can easily hear the pump being under constant pressure and when the main two outlets are put in "float" position one of the outlets gives a little pressure, if I put the lever in "lock" potion nothing happens.
I also noticed when changing the pumps that the main gear in the gear shaft that runs the pumps could be slided back and forth about 5 mm and it was not firm around the axle it could be turned a little bit or about 1-2 mm.
It just heats up really fast and the hoses from the pump to the loader and hydraulic system seems to be very stiff when its running. I tried disconnecting the hydraulic distributor for the loader and the external hydraulic outlets on the rear but no change.
I'm sorry this is almost a whole paper, I just wanted to give you guys as much info on the matter as possible.
Can any one help me with this problem, I'm nearing haying season and I'm getting worried .
