14145 Transmission Fluid level
beautolley
Beau
Do i fill the fluid to the fill line indicated on the trans dip stick while the tractor is running in neutral? Or while it is off? Also Trans/Diff/Hydraulic fluid or SAE 90W Gear oil in the trans?
You cant read a manual transmission whilst running, splash oil will be high on the stick.
It needs 10w/30 or 15w/40 UTTO (universal tractor transaxle oil)
I am not sure if 80w/90 is also allowed in this trandmission with wet PTO and TA clutches
Park level ,fill to top line with engine stopped .DO NOT USE GEAR OIL .
