3011 Cold Start Button
colestation
colestation
The cold start button on my 3011 is stuck in. I have WD40'd it, tapped and prodded it - no result. What next?
hi if i remember this corektly you shuold tvist it when you use it
grab hold of it with a plier and try tho gently tvist the button
remember to sett trotel to full sped first hope this helps
once seen someone use hacksaw to cut a slot into side of stuck in button then use screw driver to pull it out, good luck
mostly you can pull them out with a pipe wrench and some WD40
Many thanks for the suggestions. None of them worked ??? The problem was that the spring behind the button had disintegrated and jammed it solid. The answer was a new button carefully installed to maintain the original setting. The supplier was most helpful, suggesting that this problem often occurs if the Injection pump is left unlubricated. Keep it topped up
