- Joined
- Jul 5, 2003
- Messages
- 4,067
- Location
- Laag Zuthem
- First name
- Renze
- Machinery:
- 1976 5718
1967 3011
I bought a 3011 last week, the engine runs superb, it shifts smooth, only the rear mudguards were partially rotten, and the guy who tried to fix that up did a dreadful job...
when i got it home i took it for a drive, and found that the 4th gear was ticking.... closer inspection learned that a teeth of the 4th gear went missing....
Today i took it in half and rolled away the engine.
coming week i need to split the rear axle from the tranny, to pull out the layshaft from behind.
I have never been this deep into a gearbox before, so maybe one of you guys may know:
Can i take off the rear axle by loosening the bolts and taking off the PTO/oil pump shift lever, or do i have to remove parts from the pinion shaft as well ???
And do i really need the special puller, to pull out the reduction gear layshaft, or is there a standard tool that will substitute ?
It seems that this special tool is hard to get.
