3320 clutch or transmission problem
hollowhandle
Hollowhandle
Thank you for the forum. I used info from here to replace my water pump last summer.
I have a mid 90's 3320. When I depress the clutch it does not fully disengage the drive. It still drives forward at about 1/3 power. I have to stand on the break or totally shift it in to neutral.
Any helpful hints on where to look? It looks like my brake fluid reservoir is full. Where are the clutch cylinders located?
Thanks for the help.
Chip
How is the brake fluid level ? you loose clutch before you loose brakes, the feed line from the reservoir to the clutch cylinder is mounted higher than the brakes.
Then, how did you loose the brake fluid ?
Sorry for the delay. The tractor is at my property and I cannot get up there every week. The brake fluid reservoir looks good. How do I make sure it is reaching the clutch?
