Hello, this is my first post. I bought a 98 3340 about two months ago and when i was plowing snow today the clutch stopped working. I am not sure if it might be low on fluid. Where would i find the reservoir for the clutch fluid? thanks
Thank you. I checked it and it seems full enough. When I depress the pedal it goes to the floor and I see little movement of the clutch linkage on the side of the bell housing. Could it be the master cylinder behind the pedal?
thanks I checked the master cylinder and it seemed to be pumping fluid with no problems. I went to the slave cylinder and found the o rings were gone in the cylinder. I disassembled, cleaned and i am installing new o rings. I will order a new slave cylinder as a backup.
