4 WD conversion
wheelbarrow
wheelbarow
hi
im thinking about getting a 2 WD zetor 8011, and then converting it to 4WD. i have seen a picture of this done, and was woundering if the kit is still available somewhere. i guess it would involve putting in a transfer box behind the gears?
would it be aneasy job, and how much would it cost?
AFAIK it involves putting an extra gear and shaft end into the transmission. Dont know exactly, never did that.
In a UR1 you need to change the pinion shaft and range gearwheels, and install the 4wd gears as intermediate wheels on the gear range layshaft as well.
Probably not cost effective. There was a discussion on this forum a while ago about this.
