My 4340 has a hose for each the left and right sides. When I first bought it (used) one of them was clogged, and sometimes water would splash down from the little tray where the sunshade is. Try blowing out these hoses (the one that is dripping on your step may be partially blocked, and not letting the condesate escape fast enough. Good luck!
hi when water drips into cab when air con is on the drain tubes get blocked and water cannot get away, so it finds its self getting into the cab. Most pipes have flap type of valve to let water out and dust getting in, but when stood they mix and block the pipe. hope this is some good to you.
