5
5011-Fan
Guest
I will try to make this simple:
- Ran it hard and overheated until radiator was empty. (temp gauge read 100 which was BS) Cooled down with water hose inside and outside of engine. All the water went directly into the crankcase mixing water with oil . Oil surfaced in the radiotor.
- After cooling down: drained/replaced oil, replaced AIR in radiator with WATER, torqued head bolts back to 140 ft.lbs.
PROBLEM: Put-puts during cranking instead of clean steady turns until she gradually starts like normal. Does not start and I get black smoke out of the stack.
QUESTION: Is this due to lost compression ? Do I have to replace the head gasket AND the heads now? Is there a possibility that I will have other things to replace (cylinder rings). How can I test the compression of the cylinders? BTW...is it me or does a 3 CYL Zetor Engine (5011) NOT HAVE glow plugs??? Is this a compression only spark????
HELP before I order the parts...THANKS!!! Love this tractor and it is worth the effort.
5011-Fan
5011-Fan
