Have got starting problems from cold with the 5011. Checked a cleaned all connections in s/system to no avail. battery shows as full,throttle wide open and primer button depressed, a little smoke from exhaust but very slow turning over. Any ideas please. Was good starter upto about three months ago. No changes to timing ect
we too have a 5011 which is never any problem to start from cold!! you need a new battery!! been there done that, had that problem!! also make sure the earth strap under cab (by the diesel tank) has clean connections.
