5211 brake fluid leak
jeremiah
Jeremiah
Just inherited a 5211, and I know very little about it. Runs great, but zero brakes. Fluid reservoir is empty. I need to fill it back up, but cant find the brake bleeding screw. Where is that located? The manual is great, but doesnt show the loacation of this screw, other than saying it's under a protective cap. Any help is appreciated.
The bleed screws for your tractor are not easy get to, the left one is under the cab on the top of the axle portal and the right one is in the same place only there's a guard for hydraulic control levers in the way.
