5211 row of bolts on PTO gearbox cover
tom_n_ms
Gary
Just in front of the hi/low lever and thePTO lever on the gearbox cover there are 5 bolts lined uo side by side-they are close together. What are these> when the cover is removed wikll there besomething attached to each of these bolts underneath..When the cover is removed what should I look for??Cover sticksunder the seat platform ledge about 1 jnches..might be kinda interesting ti get everything to line up all at the sane time ti et the top back on......What dui zi look for when the cuver us uff>>>>Thanks
The five bolts are the detent tha holds the shiftforks from sliding back and fort, take of the gearstikk and lift the rearend as high you can you shold be able to slide the cover off/on if there is room up front by the stearinggearbox.
Bjarne
The rear of the cover goes under the platform where the seat is mounted..Looks like front would have to raise up and hopefully slide the cover 2" forward, then off..At the back you also have the brake lines running right on top of the cover bolts(totally crazy). All I know to do is TRY to get all the bolts out and see what happens and hope that the brake lines can be bent some to get them out of the way.
