Had new brakes put on, then they were bled, done by dealer. Four pumps on the clutch then i had no clutch. Reservoir is now almost empty. Dealer says I need to bleed the clutch. Does anybody know why I would have to bleed the clutch. Im thinking I must have a leak. So how can i bleed the clutch if I have a leak somewhere
if the tank of brake fluid was empty ,air has got in so both clutch&brakes need bleeding.what was the clutch like before u did the brakes?unless its a major leak u can bleed the clutch easly.
if the clutch was fine before,&wasn`t useing fluid,its sounds to me to be air in the system.you`ll have to bleed the clutch,when ur doing this be sure to the tanks topped up with fluid all the time.it u think theres a leak in it the clutch will build up for a while&then be gone wrong after awhile
Thanks I will try it tomorrow. Have another question for you. All lights worked when it went to dealer. They took dash apart, is it possible that the lights are unplugged from switch? Reason asking...lost manual!
the lights connect under the key u may take off the panel under the steering wheel&check also see that all the joiner blocks were put back right.only thing with wiring on zetors it opens a world of pain!!!!!!!! even with or without a manual ,belive me i know....
