57/11 Injection pump lube.
bignikki
nikki grant
I've just went to change the oil in my injection pump but it was basically empty of oil.
I filled it up and noticed that the oil is leaking out from where the throttle lever goes in to the pump.
Anyone know how to change the seal?
Can I just unscrew the two screws behind and get to the seal like that?
Nikki.
How much did you put in it ? 3cm in the bottom is enough... then it wont spill much. Dont know about the 5711 governor but the 3011 governor has two plugs, one for draining and one level plug.
Ah, now, there is two plugs at the bottom of the pump. The top one is the level then?
I was thinking that it should be full of oil to the top!
You do know that the gowenor and pump is separat oil filings? The two plugs in the rear only serves the gowenor and the pump is to be filed up to the overflow tube on the side.
Bjarne
