5711 jumping out of 5th?
sih
Brittany, France
SiH
Zetor 5711
Used my tractor for the first time today,to mow some grass,but still havnt got new injectors/pump yet.As I say,it jumps out of fifth gear when on the over run,-fine going up hill/under load etc.
Could it be a weak detent spring like in old landrovers? If so,where is it and which is it?
Thanks all.
It could be. then it should be the 2nd from the left as it works mirrored.
Also check your fuel tank rubbers. My brothers 6718 had a little fuel leak that ate his tank rubbers, that both cracked an put the tank leaning on the lever.
Because it wasnt fixed on time, also a 5 ct Seeger ring on the sycnchro collar went, which took a day to get at.
Thanks again Renze!
Thats what I was hoping to hear.I`ll do as you say too.Been cutting grass again today,and I`m really impressed with these Zetors-only drama was when some old electric stock wire wound itself round 2 of 4 discs! After several hours of swearing,it was fine.
All the best.
