5718 BRAKES AND BEARINGS
richard_a
Richard A
Hi, Well managed to strip tractor to do brakes , had a big job undoing the rear cab mount bolts, had to cut one side of the bolt as was siezed to inside collar, any way have it all a part and the bearing for the brake shoe holder is completely gone so will have to replace.
Now my problem is the shaft that is inside rear axle housing which goes into the portal, there is play in the shaft I took of the top cap and found a bearing --- is there a nother bearing in the portal , I HOPE I don't have to split rear axle housing from the portal as everything is so rusted and siezed, could I remove shaft if i came at it from the top cap side.
Any one had this problem before
Any idea how much the brake shoe holder bearing will cost
and the other bearing OR BEARINGS
