6341 Diff lock
diamond_b_farm
diamond b farm
My differential lock quit working. I have air pressure to it. Any suggestions for repair will be welcome.
George
Thanks Mike
It has about a ton of mud on it now. when spring gets here I'll take a look at it. My biggest complaint about these tractors is that they were not designed to operate in mud. In winter the parking brakes,4WD cylinder, PTO lever all freeze up.
George
Do you use anti freeze in the compressed air system ? I dont know if it has an anti freeze sprinkler or an air drier, but it must have something to prevent the condensate to freeze.
it has none of the above mentioned Renze, zetor has cleverly enough made a system that produces little or nothing of condensation. i have never had any mor than a little moist coming out of the system while draining it :)
The owners manual does not say anything about that. The 4WD works fine winter or summer. It may have so much mud on it that it can not work. When I get time I will take the bottom out of the cab and check it out.
George
I cut a piece of tempex or dupanel 5cm insulation board from an old pig barn to sit on: It keeps your butt warm on the cold floor...
