6345 lift stuck up
gary
gary
Hi all lift arm stuck up on zetor 6345 tractor parked
Over winter all advise welcome 1996 model4 wd
Most likely the cam follower of the lift arm has gotten stuck due to some fly rust.
try putting it in draft control and push the top link bracket rearward into a tree or pole, (you need to overcome the spring force) and hopefully that will release it without having to take the 3pt cover off.
Maybe it already pops loose from moving the D-M-P lever alone.
Then, what colour is your backend oil ? creamy white from moisture absorption ?
