Bought tractor new with a loader in 05. @ about 2 months old hydraulics stopped working, turn-off checked fluid ok no leaks, started tractor begin working. From time to time this would happen it was like the pump lost its prime started breaking the the hydaulic line @ the loader controller to prime. Now the problem is getting worse. Can crank tractor the loader may or may not work, at times it will move very slow and then start working normal. Fluid level ok change filter no help .
At times it work normal
At times it works slow
At times it works not
