6718 -77 strange levers
michael
Michael
I just bought my first Zetor and dont understand the function of these levers, i hope somebody could help me
*1 under the seat with a big cast arrow on "hydralic top cover" ?
*2 attached to the clutch pedal with a rubber damper sliding on a M8 rod ?
Does this tractor have a torque multiplier ? if so how does it works ? (is it only mechanical or is it hydralic involved in the torque multiplier as well).
Does anybody have the operator manual on pdf?
I bought the workshop manual but i dont explain the funktions
Thanks / Michael
i have sent you a message with a link.
the lever under my 6711 seat controls the rate the rear arms drop, slowly to quickly.
dont know about the other though.
Thanks Grumpy, first problem solved
I hope somebody can help me with the lever thats conected to the clutch (see picture 2).
And an Operatormanual would be nice too
/michael
I think that rubber and M8 is clutch axle brake lever. It is supposed to work when you press clutch pedal as far as it goes. This is to make it easier and faster to engage gear. I believe that it should be adjusted so that when clutch pedal is down it presses that rubber.
THANKS Vulcan
Great link, Manual in swedish too !!! it`s my lucky day
michael
