How do you decide how many adjusting shims are needed when putting clutch shaft/hollow shaft thru gear box to splined shaft ?. I am a bit confused with the washer/spacer drawings on the manual. There are different washers/shims shown in the manual. How can I put some images up to show what I mean ?. Thks
Am i right in just putting one circlip & washer on the splined shaft before the 4 th / 5 th gear synchromesh as shown to left of pic. ?. Is there a special washer/ clip with a serrated edge that should go here ?
Do the adjusting ( 2.7mm & 0.8 mm )shims go on the clutch shaft and up against the 5th speed taper assy
I was wondering about the need for 2 & 3 when assembling clutch shaft splined shaft together. I do not think no 5 & 18 were on the shaft prior to rebuild
Thanks, thats what happened me also I think circlip A broke), there is some play on the splined shaft now, but I was wondering should I adjust the play by putting shims on the splined shaft in between circlip A & the gear in front of 4th speed taper assy or do the shims go on the clutch shaft in front of the 5th speed taper assy.
