7245 Cab
scratchthebear
ScratchTheBear
Can someone tell me is it possible to lift/swing the cab up from the rear on the 7245 to access the top of the gearbox/internal lift ram. It looks like it can swing up on the front supports about 4 inches/100mm
Cheers
Take the bolts from the cab floor out and tie the seat to the steering wheel, that gives you all the room you need.
Thanks for responding
That doesnt answer the question since if the cab will move up slightly it would improve access for getting an engine crane into place etc.
You must also remove the kn n the pmd lever, and tkae off the cover of wich the three point hitch and outlet levers og trough, and you may have to disconnect pick up hitch cable. then undo the bolts for he seat platform ad hoist i up towards steeing Wheel and tie it up With a rope then you have all the Space you need
