7245 hydraulic linkages in the top of the axle
scratchthebear
ScratchTheBear
Does anyone have an pictures of the internal linkages on the 7245 which control the hydraulic output in the top of the rear axle above the diff.
We have discovered that ours has become disconnected by removing the pump plate to check the pump and finding part of the linkage and a cotter pin minus the circlip sitting on the top of the pump plate. There were some fragments of something attached the the filter magnet which I guess is the remains of the broken circlip.
I have the same issue. Shift lever flaps with no resistance. How did you repair the linkage? Thanks
