question 7745 driver seat
A lot depends on how much you want to spend? You have a wide choice. There are some very cheap or very expensive seats out there, that would fit.
Would you have any links to some seats to gauge prices. I can't find any online
I don't have links but I having dealings with Zetor Ireland and Paul Brogan and I saw different ones right up to over a thousand euro. You can still the old mechanical seat that would be in that tractor as they were the same in the 8111 type.
A Grammer MSG 85A (mechanical) or Grammer MSG 95A (air) will fit. Also the own seats from Granit parts.
The main problem with ALL of these seats: the seats are usually too high, if you want to stand up you will want to move the seat back to get between the seat and the steering wheel.
Take also a look at there:
They are also usually a bit wider than the original seats from MARS (CZ) so you can see less to the back through the lower window.
But it works...
I have in my 5011 with BK 6911 cab or on friends Zetors with BK 6011 this one: Grammer Maximo Comfort Plus with APS MSG 95 A / 731
Other use the Probos from Granit: Proboss 2480
It's a Grammer air seat is in my HSX. It reclines and swivels and the armrests are adjustable. It has black fabric with a headrest. Them seats new are well over a thousand euro.
