7745 oil change
shawt04
Terry
I want to do an oil change on my father-in-laws 7745. I can't seem to locate where to put the oil into this motor. There isn't a port on the valve cover or a oil neck on the intake manifold. I feel silly asking this, but there isn't anything obvious.
there is a big red cap on the rigthand side of the engine, above the startermotor.
I put 12 liter of fresh oil direct in engine before replacing the oil filter.
The hole is verry large and it is very easy to put oil by this way.
You can add a little oil by the red plug after for the correct level.
its on the centrifugal oil filter housing. i think its 22mm hex head.
