8111 gearbox input shaft seals
f130dt
f130dt
hi all
Does anyone know anything about the input shaft seals ? Inside the trumpet that the release bearing slides on there are 2 seals 1 directly onto the pto tube and one on the flange that comes through the input bearing . My question is ,is there another seal inside this flange that seals onto the end of the tube .the tube looks as if a seal has been running on it .if there is no seal I cant figure out what stops oil leaking out between the two shafts ????? Any help would be great .cheers
