9540 pto
sb
sb
hi now i need help on the pto of my new tractor . as far as i can work out i can take shaft out at back and turn it around is that shaft a 12 spline.. is there any way can run the 540 shaft at a 1000rpm thanks
Yes there is a way of changing to 1,000 rpm with 6 splines, take shaft out find M8 nut & bolt correct length to fill hole flush on 21 spline end, refit shaft result 1,000 rpm on six splines. To change back to 540rpm simply remove nut & bolt
