- Joined
- Jul 4, 2010
- Messages
- 90
- First name
- grumpy
hi folks
just got around to changing the Right Hand brake on my 6711 and before i put it back together I have two questions-
1. In the workshop manual the leading shoe and trailing shoe have slightly different profiles.The shoes coming off, both the leading and trailing shoe are identical to each other. One of the shoes is broken. The new ones to go on are also a matched pair (and they are the same as those coming off).
So has the design changed slightly over the years and it is correct that they be a matching pair??
... or should there be a leading shoe and a trailing shoe and this is possibly why it broke in the first place??
As far as i can see the 'shops' only list 1 RH shoe and 1LH.
question 2 - regarding the slave cylinder.
The bleed valve comes out at the opposite angle to the one coming off, but as far as i can see will still fit and be adjustable when in situ.
Is this correct?? or have i been sent the wrong side?
There are pictures of the old and new here.... https://www.dropbox.com/sh/rok652hrfcc1t4l/X1RL4FLwle
thanks in advance
nev
thanks in advance
nev
