- Joined
- Jul 5, 2003
- Messages
- 4,021
- Location
- Laag Zuthem
- First name
- Renze
1967 3011
5245 is very hard cranking. Tried two batteries, but both are used for a year to start it without a working alternator, which means start untill depletion and then charge them with a 220V charger. So they might both be busted.
Whats the voltage drop of a good battery, between no load, and when the starter button is pushed ? I measured 12.8 volt yesterday after 3 days of charging, but my brother left the ignition key on so 12V this morning with no load, .5 V when cranking.
I need to know the Volt measures for a healthy battery and how to check if the battery is busted, or just depleted.
