Brake cylider(pump) change on a 6245
bonde
odleiv grinaker
How can I easily get access to change the brake cylinders(pumps) on a 6245?
By removing the pedals or is there any other way? (I know they are placed just behind the pedals)
Anyway- is there anyone who can tell me how to get it done the easiest way?
Its most easy by taking off the plate on the front of the cab: between engine and cab. It gives an allmost unrestricted access to the area under the dash.
The previous time i accessed from the pedal side, but i had to pull very hard on the brake lines to pull the pedals and cylinders out far enough to undo the brake lines. accessing from front is best, remove the plate with 4 M8 bolts.
