Brake Parts
kjhanscom
Kevin
I'm getting ready to purchase parts to overhaul the braking system on my 5245. This is a big undertaking, so I want to make sure I'm using the right parts.
I have already replaced the master cylinders and I am now purchasing Zetor OEM brake pads, slave cylinders, seals and springs. Are these OEM parts the best replacement parts. I don't want to be doing this again. Plus I will be using DOT 3 brake fluid. I think the cause of the brake failure was likely due to me adding a different type brake fluid than the original owner had in it. Will DOT 3 fluid be adequate?
Also, are there any other parts (seals, etc.) that I will be needing in order to reassemble the axles/gear portals?
Thanks in advance for the info.
Kevin
...Not that i know...
I need to do that operation this winter, one brake sticked and is now worn till the metal. it scrapes amd squeeks.
Dot 3 will be fine, it's not a racing car. all non silicon brake
Fluid is compatable. dot 6 fluid is silicon based and not suitable.
