Brakes on 5245
zetor5245
OLLE
How difficult is it to change brakes on a 5245?
I need a complete instruction because my repair manual says nothing about it.
Thanks!
Olle
Sweden
It is not a difficult task but the parts are hevy, you have to put a jake under the sentral part of the rear aksel lifting one side, after remowing the wheel you losen and lift the cab at the rear end then you undo the brake pipe and the round flange holding the halfaksel to the sentral body, you will nead a crane of some cind to lift out the halfaksel and you migt have to slak of the handbrake band that goes around the brakedrum,this is done trou the cabflore there are a hole on eacs side of the driverseat. Onse the halfaksel is out there is a C clip holding the brake drum in place. You shold replace rubber seal behind this C clip vhen you replace your brakes. Hopes this helps.
Thanks!
I need all the help i can get before i try to fix the brakes this summer.
Pictures would be very nice if someone have that
