brakes
j2759
chad
i have a 1991 4x4 5345 zetor and it is loosing brake fluid some place,i have checked the lines,the master cylinder,the slave cylinders behind the brake pedals and the clutch.NEED ALITTLE HELP
the feed lines from the reservoir to the master cylinders may crack and leak. They can trick you, and only spill fluid when the crack is bent open.
And if not, it must be the slave cylinders.
Could be brake compensator/air brake valve leaking from air brake piston on the compensator.
