clutch wont depress
decemberpoker
Dane
Hello everyone. I am having trouble with my 1986 6245. I parked the tractor with everything working fine. A couple days later, while trying to start the tractor, the clutch would not depress. Where should I start to diagnose this problem. Any suggestions would help greatly. Thanks
hi have you mabye caned the master sylinder ? iff so adjust pushrod so fluide can return to tank it sjuld have a fre play on pedal off 1-2cm , chek pushrod it might have com lose .
so if i understand correctly, the clutch pedal will not budge? if this is the case, something is seized or has buckled, check the master cylinder at the pedal (pushrod and piston)
it will depress a bit but not far enough to hit the button that allows the ignition to engage. If I try it a couple more times it seems to get much stiffer with each attempt.
