Condensation on 7441
andy
andy
I just bought a new 7441 and I have condensation from the A/C dripping from the roof through the speaker. Does anyone know a fix? Thanks.
Hi Andy
Any condensation from the air con rad and pipework should be collected in a "drip tray" under the rad. There is a drain pipe down the cab frame each side to drain this away. Your pipes are either blocked or disconnected. Try putting an airline on the bottom to make sure they are clear. You'll find them at the bottom of the front corner cab frames.
i had the same problem with my new 7441 it turned out the roof was leaking through the hinges on the sunroof nothing to do with the ac.
