I drained and flushed the coolant from my 7341 a few weeks back and re-filled with fresh antifreeze mix. The first couple of times I used it after that, I checked the level and found I had to top it up a bit and didn't worry because I assumed that was due to airlocks clearing. I've had to do it several times now though - is this fairly normal?
I can't find any signs of coolant leaks anywhere, and I don't suppose it's supposed to "consume" water. I've heard that head-gasket leaks can cause water to escape the water jacket and mix with the engine oil. I checked the oil and it looks[/] OK to me (a bit dark, but not looking emulsified), and the engine seems to be running sweetly enough, but should I be worried anyway?
