- Joined
- Nov 30, 2011
- Messages
- 1,749
- Location
- Republic of Ireland
- First name
- diy farmer
- Machinery:
- Zetors HSX 140, 2x 8111. CNH 895, MF50B. Heap of machinery.
Yes Hazze Morrie this correct, it would get about 40C when engine is hot.
The gasket might come away when you open the housing but you could use a small line of silicon around the edge.
About the fuel filters, I looked at them all they should be right. There's a primary and a secondary filter, though when we used to service our 7245, we used to the same filter into both of them.
The last one is a type that would fit my HSX.
That gasket looks the job OK.
If the glass vessel is full gunk clean it and fills up again quickly with a gunk again must be coming out of either the filters or all the way from the tank. You should be changing the filters every 300 hours or once a year. The tank might needs cleaning after 10 years.
To change them, first turn off the diesel at the tap stick a bucket underneath open the bolt on the first filter screw of the cover, empty the old diesel and filter into your bucket and rub the inside of the housing bowl with a rag, then do the same with the other one.
To fit the new ones, pop in the new filter into the housing bowl and fill up 3/4 full with clean diesel then screw it back on, then do the same with the other one but don't retighten to the last, turn on the tap and pump up the diesel with the hand primer and when the diesel starts coming out of the filter bolt tighten them up to last.
To bleed them open the banjo bolt at the second filter and pump the primer till diesel is flying out then tighten the banjo and try start the engine.
where is the tap to turn off diesel, ( near filter ?) I only leave the 2nd filter hand tight until I pump the primer or do I leave both loose?
Where is the banjo bolt on the filter ?
Also they are labelled and as you look at them they are 2 and 1 from left to right . Is 1 primary 2 secondary.
Is there not a tap over the glass vessel. I have not worked on a tractor like yours since the early 90's so maybe my memory is being mixed up by all the Crystals I worked on.
I would leave both of them hand tight first, then pump the diesel when the first one is overflowing tighten it and do the same with the second one.
The banjo bolt is on the filter housing where it comes out heading for the injector pump, open that for bleeding the system rather than the bleeding screws, it's a much faster way of doing it, only bit messy. The filter closest to the diesel tank would be the primary.
Thank you, you have nothing to fear when your changing the filters only be careful not to over tighten banjo bolts and screws as they are made of soft stuff.
Surely fuel filter 1 is primary and 2 is secondary altogether two is on the nearer side of the fuel tank.
Sorry I don't understand.Not unless the pipe coming out of the tank is bolted to filter housing at the secondary side.
Yes that is exactly the way it is supposed to work. So that's all fine
Changed over the fuel filters there, was very easy after your tips - thanks diy farmer. Will get round to thermostat soon !
Fitted new thermostat and it's reading perfect on gauge. Gradually moves all the way up to just shy of 80C (ie the edge of green ) .Got up to 75C and when I disconnect the temporary earth needle goes straight down to zero. So I've a permanent earth in it now and works fine . Once again thanks.
You should really start a new thread for this problem for on the forum for other user to follow as it's now different what you started.New question for ye. Engine oil light stays on all the time recently ( on the warning light cluster ) Oil levels are fine and sensor seemed visually okay when I took it out but not really sure how to check sensor. Sender cable from sensor is fine.
Yeah strange alright, gauge has 12V at it so there's an earth there. And when you said earlier doesn't need earth I figured that was right as there's no "proper place for an earth to attach" but needle drops back to zero if temp earth was disconnected but hey it's workingIt's good that you got it going now, funny that the manual doesn't a need for an earth at the sensor, but sure if it's working like it's supposed to, that's the main thing![]()
If the engine oil light is on all the time means, engine oil is low. oil pressure is low. sometimes if oil wasn't been changed in a long time. Again it can an electric problem, which you might find it's the sensorNew question for ye. Engine oil light stays on all the time recently ( on the warning light cluster ) Oil levels are fine and sensor seemed visually okay when I took it out but not really sure how to check sensor. Sender cable from sensor is fine.
Got around to put in a new oil pressure sensor. Oil pressure light is off now. ThanksIf the engine oil light is on all the time means, engine oil is low. oil pressure is low. sometimes if oil wasn't been changed in a long time. Again it can an electric problem, which you might find it's the sensor
