Hi Differential shaft---- HOW DO I get to remove the Differential shaft as I have a bearing loose between portal and rear axle housing.--------- am trying to replace brakes and want to do right job or should I just put the 5718 back together with play in shaft--- the brake shoe holder bearing was completely shot, not even a ball bearing to be seen so must try and replace seals as well. Please someone help me, has anyone a manual that they can down load for me.
