Hello fellow
Zetor drivers
Im a proud owner of a 6045 -82 that i use mostly for forestery work and for this the tractor works great.
I also often use it for transporting loggs to the mill, bringin home firewood and so on. These transports usually takes about a hour or so and it would be nice to speed it up a bit.
Can i adjust the pump to get a higher rpm? How do i do this? is it safe? After all its still a tractor and not buildt for high speeds but a little bit higher rpm should be ok or?????
Whats your experience?
Best regards,
Mattias
