Here is translation from konedata.
"Begin of 1985 introduced model were known in finland called Finn-
Ursus, and had many techical differences to international technical specifications. The biggest model 1614 was not imported to finland. Either 71 and 90 hp models wasnt imported. Model 1014 was available only after 1987.
Turbo models chargers were still fitted in finland, except model 1014, wich was factory charged. Clutch diameter was now 350 mm (4 cyl) and 380 mm (6 cyl), before it was only 335 mm. Share of finish work, of out selling price, was about 50%. Finish made was dashboard, external
hydraulic valve block, bonnet and roof element with heater and blower. Gageing of 4 wd was controlled electrically, but front differential lock was still not fitted, also side mounted 4 wd shaft was "old fashion" technic. Allmost half of buyers selected Transport transmission as optional, wich offered nearly 40 km/h speed. Highest speed of standard model was increased to 34 km/h (in finland) year 1987. Year 1990 steering was changed to hydraulic (instead power steering).
Year 2004 was still produced models 1014 and 1614."
In table:
ei FIN = not sold in finland
mek = mechanical
kuivat levyj. = dry disk brakes
tehost./hydr. = power steering/ hydraulic steering
ei = no fitted
I hope this helps you a bit. Sorry my poor english
