gear oil leaking
i have the same problem with my 6711. i solved it by parking on a hill with the back end higher than the front. simples :):)
You've got to be careful doing that, Grumpy, its much easier to change the PTO seal than an oily clutch plate
hows oil leaking out round the pto shaft going to get on the clutch plate?
i guess Dave would be working on the assumption that if the seal on one end of the shaft is b*&**&*ed then theres a good chance the one on the other end is too?
